no coolant
On inspection day they will open the radiator cap to see whats in there.
here is the link, see page 21: http://curacaodrag.com/myimages/down...ules2011v1.zip
Water wetter for corrosion resistance and you will be all set. Distilled is best because it doesn't have all the chlorine and chemicals like tap water does.
I think I might be the only one besides you that understands the rule book in Papiamento.
Ki class di auto bo ta pusta no Curacao? Mi tin un Trans Am cu mi ta pusta ki nan na Guam. Mi famila ta di Aruba.
P.S. Stop with the gibberish! English only! hahaha
Again maybe if you have some info to support your suggestion I could be wrong but I am pretty sure this is a HORRIBLE idea.
hey Cutm2500 i just sent a PM to Caribe so we can keep the gibberish(papiamentu) to our self btw i think your truck is on fire (maybe you were going to fast or I past you by so fast it caught fire)..HAHAHAHAHAH
Before there was Ethylene Glycol that is what was used. In the old days you had to have your car winterized. Part of it was changing from all water when the weather got colder.
Does it evaporate in your winsheild washer bottle? Evaporate in a closed system?
Read the statement below the line.
I will continue to use my "horrible" idea.
Especialy since there is no benefit that I can see.
You guys sound like you change over to antifreeze afterwards and continue to drive the car. If that is the case just use water.
Your washer fluid is a good and interesting idea, I don't know if the cooling effects are the same, and that would be my only concern about doing it.
