Drag Racing Tech
RHS tall deck intake adapter
Old Feb 19, 2011 | 11:33 PM
bandit383's Avatar
Default RHS tall deck intake adapter
Anyone using a RHS Fast LS7 102 LSX intake and RRHS intake adapters on a tall deck LSX... When I went to install the intake on the adapters the locating pins were right on butt the bolts are off by about a 1/2 hole.. Also the LSX intake bolts were way to long.. The only thing I got with the kit was bolts for the adapters to heads and that’s it… I Haven’t been able to call their tech.. found the problem Fri afternoon and their tech is closed when most people work on their cars…
So I have couple of questions for the tech world
1. Has anyone else had problems using adapters?
2. What hardware did you get with your adapters?
3. what seals did you use on the adapters?
4. What did you TQ the adapters to?
Any help here is greatly needed...
Old Feb 20, 2011 | 06:15 AM
Firehawk441's Avatar
The way I read your question you're using RHS adapters on an LSX block.
Are you using an RHS block or an LSX block?
Reason I ask is because the RHS has a 9.75 deckheight and the LSX is a 9.70 deckheight.
This would most likely be your bolt alignment issue.
Old Feb 20, 2011 | 10:46 AM
bandit383's Avatar
LSX... That would make sense... I got the whole thing as a kit from a shop..
