Lite Weight Steering Column
I have a Grant wheel with quick release hub on a stock column now.
I'd like to get a column that will work with my quick release hub.
I think I got my hub and wheel from Madman, not sure.
Thanks guys
Thinking about it a 2nd time, there's wheel spacers that you can get that will space the steering wheel back.. I have seen them in the ART catalog I have, and they're available up to 5 inches long. Had I known that, I would have had the column made 3 inches shorter then stock, and got the wheel the 2 inches closer with the long spacer, which bolts up between the wheel and the quick release hub.
This, would make for alot shorter column to deal with when getting in and out of the car...
Just something to think about. When putting a column in, you have the chance/ability to move the wheel position to make you more comfortable. There's a few ways to go about that... some might work better for you then others.
Burkhart can for sure take care of you as well... they've done lots of
stuff with parts for these cars, and every one I have ever gotten from them has been 110% Trending Topics
stuff with parts for these cars, and every one I have ever gotten from them has been 110%It is getting harder and harder to get in and out of the car these days. I do have alittle beer belly and alot older.
Never thought about a shorter one with a spacer.
Do you think that the spacer would be ridgid enought, and not going to flex at the hub. How much do the spacers sell for.
http://www.appliedracing.com/index-2.html#/Applied Racing Technology 2011 Catalog/14
$115 for the 5 inch one.
I think it would be plenty rigid. If your wheel feels rigid now, I can't see that spacer, with it's large diameter deisgn feeling anything less then solid. Only thing you might feel is a little wobble from the sfi hub being increased becuase of the distance, as mine has a slight wobble to it. Not bad, I can't say what it would feel like at a 5 inch distance.... but that's the only thing I can see causing anything resembling a loose feel.
One thing is for sure, if you made the column 5 inches shorter, how easy would it be to get in and out of the car? Even the smaller 3 inch spacer they have, would surly make it easy.
The Burkhart setup doesnt look like there is anyway to adjust, all the positions are fixed and welded when it gets to you.
I was able to tell DMH where I wanted the wheel compared to stock, about the same height, just closer to me by 2 inches. I think the colum was built to drop the wheel an inch, but due to the increased length, it's in the same stock height. Worked out great for me.
