Drag Racing Tech
Yellow box under console
Old May 30, 2011 | 10:05 AM
ronnieabene's Avatar
Default Yellow box under console
What is that yellow box under the console. Is it for the air bags? Will car run without it being hooked up? Removing all unnessery weight.
Old May 30, 2011 | 10:15 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
If there is a thick yellow wire going to it then yes it's for the airbags
Old Jun 1, 2011 | 09:48 AM
PRAY HRD's Avatar
airbag module and yes, it will run but your check/service engine light will glow. 1 or the other, can't recall at the moment.
Old Jun 2, 2011 | 04:50 AM
DietCoke's Avatar
It lights up your airbag light, actually (remove the bulb). Anything bright yellow is airbag related.
Old Jun 2, 2011 | 10:05 AM
PRAY HRD's Avatar
It will also throw your service vehicle light, not service engine. I'm not sure if i can pull that bulb as i don't know what all could trigger it.
