Drag Racing Tech
Questions On Screwing Slicks
Old Jun 1, 2011 | 11:02 AM
GARY2004Z06's Avatar
Default Questions On Screwing Slicks
Can slicks can be screwed one side only?
If so, how many?
If both sides must be screwed, how many are recommended per side?
Specs on the car are as follows:
C6 Z06
Approximately 500 RWHP
M&H 26x12x16 Slicks
60's from mid 1.3x to low 1.4x range
TIA
Old Jun 1, 2011 | 01:47 PM
Duffster's Avatar
500 rwhp... how much torque? Have you had an issue w/the wheels spinning inside the tires?
Old Jun 1, 2011 | 02:36 PM
About 460 TQ
We never marked the tires to check.
Old Jun 1, 2011 | 04:38 PM
studderin's Avatar
I think these guys now a little bit about tires
http://www.mickeythompsontires.com/tech.php?bulletin=s4
Old Jun 1, 2011 | 06:00 PM
tektrans's Avatar
Mid 1.3's will spin a tire on a rim. Pretty sure it's 8 per side. U can but the kit from summit/Jegs. Comes with template and all the screws. Both sides must be screwed.
I always used a little clear silicone dabbed in the holes before running in the screws.
U said 16" rims. Whats the lip look like on the rim u r using? Got enough meat/surface area for screws?
Old Jun 2, 2011 | 02:03 PM
Thanks. Good read.
Old Jun 3, 2011 | 04:55 PM
1nastyss's Avatar
Be safe and wear a rubber
