Drag Racing Tech
Help with distribution block wiring.
Old Jun 17, 2011 | 05:16 AM
whiteboycntdnce's Avatar
Default Help with distribution block wiring.
I just need a little help in figuring out the best way to wire this distribution block up... I tried sending a picture via my cell phone, but for some reason it has yet to come through, so I apologize for having to use a web site picture. This is the unit I have, Street Wires, Fused Distribution Block - FBX0024 or http://www.streetwires.com/products/default.aspx?grp=63
I currently have 160 amp fuse in middle, an 80 amp fuse on one side, and a 60 amp fuse on the other. I need to know what cable (Starter/Alt/Fuse Panel) needs what fuse. Also, what will be the best way to run the cable? I know if I run them with the 1 gauge coming from the battery, and all 3 other cables on the opposite side, they will be sharing the 160 amp fuse, I would like to avoid doing that. Any help would be awesome, thanks!
