Drag Racing Tech
What wheels with Moser 9"
Old Feb 27, 2004 | 10:59 AM
00Streak's Avatar
Default What wheels with Moser 9"
What drag wheels/tires are you all running with the Moser 9". Was there any grinding involved?? How are your fender clearances? Is the car lowered or stock ride height??
Thanks
Scott
Old Feb 27, 2004 | 11:15 AM
Durien's Avatar
i am running ET streets with mine............ 26" X11.5" on a 16" rim
in order to fit ET Drags i need to grind the calipers... since et drags only come in a 15" size for our application
Old Feb 27, 2004 | 11:43 AM
00Streak's Avatar
so r u running welds?? what brand of rim?
Old Feb 27, 2004 | 11:52 AM
SilverGhost's Avatar
Motorboater
Weld Prostars 15X10
alot of grinding to make them work.
its not the rearend that mattters, its the calipers that are the problem.
Old Feb 27, 2004 | 01:08 PM
00Streak's Avatar
alot of grinding due to not using the shims right.. or did you have to grind and use shims? cause im thinking abuot getting the welds as well. and the grinding only takes place on the rears right?? i polished my front calipers and really dont wanna grind on em.
S
Old Feb 29, 2004 | 04:46 PM
Navy David SS's Avatar
Convo Pros .. no grinding, no spacers. BUT the bigest B/S is only 5" B/S. You can run 15x7.5 or 15x8.5 with some 26x10x15 ET Drags and they will not stick out to bad (due to the B/S). I have a Moser 12-bolt narrowed by 1.5" on each side. I fit 28x10.5x15 on 15x10 Convo Pros. No banging, no mods, no spacers, no grinding
David
