Drag Racing Tech
oil air separator? for PCV
Old Jun 27, 2011 | 04:10 PM
00blacka4's Avatar
I write checks with my mouth that my ass can't cash
Default oil air separator? for PCV
my buddy is giving me one of these for free its like 75 bucks or something...its a little clear thing that goes between your valvecovers and intake manifold...will it work ? im going to a vacuum pump and really dont wanna buy an expensive catch can if this is just as good thanks
Old Jun 27, 2011 | 04:27 PM
JL ws-6's Avatar
Race your car!
Nothing really works 100% to stop the oil from getting into the intake, other then not hooking the crankcase and the intake together.
It will help yes.. but it won't be the end all fix. If you're looking for a get by type of thing until you get the vacuum pump on, yes it will work.
Old Jul 7, 2011 | 12:08 AM
silverz28camaro's Avatar
I like to delete the breather side from the throttle body, install a nice little stainless steel mesh filter from O'Rileys onto the pass. side front valve cover vent, also install a filter on the drivers side where the old PCV valve was, and hook a vacuum hose from the manifold on the rear pass. valve cover vent...I use that with a small restrictor inline to keep "AS MUCH" oil from going down my intake. If no breather is hooked up you will get a slight oil smell or steam/smoke from those vents.
The factory setup is a problem because it is all tied into the intake, so at WOT all vapors get sucked into the manifold vs having a few vent to atmosphere.
I have done this on both mine and Ericas z28's, also the LS1 ram..
Old Jul 7, 2011 | 12:10 AM
I'n not against catch cans, I just prefer a cleaner looking setup if possible
