Drag Racing Tech
Tach, temp, and fuel gauges not working
Old Jun 29, 2011 | 03:18 AM
ss2000's Avatar
Default Tach, temp, and fuel gauges not working
Finally got my car back together and the tach, temp and fuel gauges aren't working. I was extra careful when I was removing wiring, but I hope I didn't cut one. Alt. and oil pressure and speedo all work. Fuse is good. They do jump a little when I first hit the key. Any thoughts? Thanks.
Old Jun 29, 2011 | 03:56 AM
HASTINGSRJ's Avatar
ground maybe?
Old Jun 29, 2011 | 10:29 AM
5.3LJimmy's Avatar
You say you got the car all back together. It would help if you explained what you had it torn down for and what you have modified since the gauges last functioned properly. There are two grounds that connect to the cluster and it is possible that one of them is not grounded. Also all the non-functioning components are fed by a single data wire(class 2 serial data signal) that could also cause lack of gauge function. This can be caused by the wire being disconnected or a short to ground anywhere in the data stream. You should get a DTC for class 2 communication error if there is a short.
Old Jun 29, 2011 | 02:11 PM
Heyfred's Avatar
This same thing happen to me and it was the the plug in connection that went into the steering colum. I had removed my dash.
It is easy to check. Remove the panel under the steering colum (2) pillips screws and (2) 7mm bolts. Once cover is removed, start the car, wiggle connections and see if guages start working. Also, unplug and plug connections back together to make sure ther is no corrosion on the terminal pins.
Old Jun 30, 2011 | 06:55 PM
ss2000's Avatar
I had the motor/trans out and removed the dash to get some weight out from back there. I was careful not to cut any wiring other than what was left from the hvac, radio and air bags that I removed a few years ago. All the gauges worked up until the re-assembly.
Old Jun 30, 2011 | 06:57 PM
ss2000's Avatar
[QUOTE=Heyfred;15097616]This same thing happen to me and it was the the plug in connection that went into the steering colum. I had removed my dash.
You mean the same 3 gauges that I'm having trouble with?
Old Jun 30, 2011 | 07:59 PM
Heyfred's Avatar
yes
Old Jul 2, 2011 | 06:50 AM
ss2000's Avatar
Originally Posted by Heyfred
yes
Still no luck, I can't find any loose connections.
Old Jul 5, 2011 | 02:51 PM
SS4Luck's Avatar
I had the same problem and it was a fuse in the side of the dash. I checked and re checked and one was barely popped and i didnt see it until I really actually payed attention. If all your connections are good that is the next place to check.. maybe with a test light to see if you have power to the right places?
Old Jul 8, 2011 | 06:44 PM
Heyfred's Avatar
Did you get your gauges working?
I told you the wrong connector to check.
Here is the one to check. It is under the dash, to the right of the steering column. It has a plug in the connection. Pull the plug out and reinstall.
Old Jul 8, 2011 | 10:06 PM
ss2000's Avatar
[QUOTE=Heyfred;15130244]Did you get your gauges working?
No, they still aren't working. I'm taking it to my buddies shop Saturday and he's going to check it with his Snap on scanner.
Old Jul 9, 2011 | 09:02 AM
Heyfred's Avatar
When the gauges were not working, my scanner did not work when plugged into the OBD port and it was do to the connector I just showed you.
Old Jul 9, 2011 | 03:09 PM
ss2000's Avatar
Well, thats good to know. My buddies scanner couldn't communicate with the computer. I cut that plug out, I don't know why. I'm going to re-connect them and hopefully the gauges and the obd II port will work.
Old Jul 11, 2011 | 08:40 AM
5.3LJimmy's Avatar
That will do it. All you need to do is twist all the wires together and solder them or put a good crimp connector. No need to put the splice pack back in.
Old Jul 17, 2011 | 02:10 PM
ss2000's Avatar
Well, I got the gauges working, just have to check the obd II outlet. I must have accidentaly cut out the splice pack.
Old Nov 27, 2023 | 08:12 PM
Martinshere's Avatar
What was the problem for the gauges not to work?
Old Nov 28, 2023 | 08:40 AM
ss2000's Avatar
Sorry, I honestly can't remember, 12 years ago.
