Launching Methods
https://ls1tech.com/forums/new-ls1-o...questions.html
https://ls1tech.com/forums/new-ls1-o...anna-fast.html
This should help you get started.
To make a long story short, have fun, practice shifting should be your main priorities as you need to "learn" the car.
M6 racing requires suspension to make you quick and your rear end is garbage so not much you can do.
Line Lock (do a search), locks the front wheels and allows for easier burnouts, you should not need much, maybe a clean off of rocks on street tires but no real burnouts. As for decent alunch again, learn the car, bring the RPM's up and then let out the clutch and input the throttle a quick but efficent manner. Avoid Bogging and Spinning and then shift accurately.
