Drag Racing Tech
Help with intake selection?
Old Aug 15, 2011 | 09:56 AM
CHEVYMAN434's Avatar
Default Help with intake selection?
It on a ls2 max effort build.It is a nitrous car with VERY good heads.Im tryin to reach over a 1000hp on gas.Cant really find much info on intakes.The manufactur's don't know either.Called eledbrock and fast too.No help...lol
Old Aug 15, 2011 | 06:20 PM
Firehawk441's Avatar
Something like this intake from MAST should work for you.
Old Aug 15, 2011 | 09:49 PM
csjta2's Avatar
Good choice, I have one from Mast and I am very pleased with it
Old Aug 16, 2011 | 07:16 AM
Default .....
I see.But that setup there would be like 4k or more.lol....I guess i would want to know if the super vic would have more power potential than a fast 102 combo.Cant find any kind of flow info,or any info for that matter...The mast intake for sure is the way to go if you got the dough,but we po boy racin here...lol Been lookin for a used beck or wilson,but there is not one to be had...
Old Aug 16, 2011 | 11:45 PM
nmass399's Avatar
I would look and see what some of the fast nitrous and all motor guys are running, maybe one of them are runnin a super victor or victor jr.
Old Aug 17, 2011 | 03:11 PM
Demonicbird00's Avatar
poor boy and max effort dont mix...
max power will be ITBs but thats at least $3k
i vote super or jr
-brandon
Old Aug 17, 2011 | 04:43 PM
JL ws-6's Avatar
Race your car!
For the money, the super victor, with the ports done to match the heads would be a decent choice. If you have the means to match the ports up on a super vic, I would look at that. You can do one for less then 1/2 the cost of the mast intake, and you can call and get one shipped to you same day from a ton of places, the mast one, you will wait for it for a while, and like said it will be at least double the cost, if you have it cnc ported and hand finished it will be almost 4 times the cost, intake to intake.
Mast will make more power, but if you are spraying the thing you can always add a little more jet, and spend that $ on a better nitrous system, stronger bottom end parts, etc.
Old Aug 17, 2011 | 04:59 PM
I'm not sure how fast you're looking to go on a budget max effort Nitrous build. Since you're considering a FAST intake, here's a basic 400 in. LS2 that we went 8.9 on a 26 jet @ 2980# raceweight and a 4 speed manual tranny. This is with a FAST 90.
Old Aug 17, 2011 | 05:07 PM
nmass399's Avatar
If you could get the truck fast 102 in there then that would be a good choice, but if not i would run the super victor for the cheap as jlws6 said plus its aluminum in case of a back fire. And there is the holley intakes if clearance is not a problem, i like the longer runners that they have.
Old Aug 17, 2011 | 07:07 PM
SSPerformance's Avatar
Originally Posted by JL ws-6
For the money, the super victor, with the ports done to match the heads would be a decent choice. If you have the means to match the ports up on a super Vic, I would look at that. You can do one for less then 1/2 the cost of the mast intake, and you can call and get one shipped to you same day from a ton of places, the mast one, you will wait for it for a while, and like said it will be at least double the cost, if you have it cnc ported and hand finished it will be almost 4 times the cost, intake to intake.
The Super Victor Dose not Come close to the mast intake.... I have tested 3 intakes... I would not put a shitty edelbrock intake on my car if you payed me.... there are alot better choices...
Old Aug 17, 2011 | 07:46 PM
JL ws-6's Avatar
Race your car!
To each his own. Not every intake works with every situation, and if it wasn't touched, vs being touched, vs being touched the wrong way, etc. Too many variables to just throw any of the intakes totally under the bus.
Hell I remember that 440 you are now in posession of running 8.23 with the GM intake on it, and that intake was untouched..... so to say any of them are junk or shitty isn't really fair.
If the OP is building a max effort I would spend the money on a sheet metal... that will make the most power. if you can afford it, do a dual top mount TB setup.. it's worth another 20 over a single. Nozzle placement, or available nozzle placement is better with the sheet metal as well. You can fit 3 foggers in the runners easily on most sheet metal and a 4th stage inside if you so desire, or some combo of the above depending on what you want to do.
Old Aug 17, 2011 | 07:53 PM
Here you go more "Theory Racing"
Old Aug 17, 2011 | 07:59 PM
JL ws-6's Avatar
Race your car!
No therory to that pal. Any intake can be screwed up if you put a grinder in the wrong hands.... and any intake can work if the valve events are right.
Old Aug 17, 2011 | 08:03 PM
Rick Who plumed that intake.... someone did a nice job
Old Aug 18, 2011 | 05:34 PM
No therory to that.
That would mean you are talking from PERSONAL EXPERIENCE.
Please share with us what YOU have used an Edelbrock manifold on and what manifolds it was compared to and why it was better then the others.
Since this thread is about a Nitrous engine, only share your testing with a Nitrous combo.
Old Aug 18, 2011 | 06:12 PM
dnkynrbk's Avatar
How much does that car weigh? dam thats moving.
Old Aug 18, 2011 | 06:19 PM
2980# raceweight.
Old Aug 18, 2011 | 06:24 PM
Agreed between the 2 of us i think we have owned every intake under the sun...
Old Aug 18, 2011 | 06:42 PM
Probably. That's why I'm only interested in others comparisons. Not their theories.
Old Aug 18, 2011 | 07:01 PM
ATVracr's Avatar
I love Theory racing.
We have also tried just about every intake under the sun.
At least thats what my bank account says. LOL !
