Drag Racing Tech
Installed some CF door panels
Old Sep 15, 2011 | 06:54 PM
SSPerformance's Avatar
Default Installed some CF door panels
Bought these from a guy on yellowbullet they fit very nice
Attached Thumbnails Installed some CF door panels-imag0048.jpg   Installed some CF door panels-imag0049.jpg   Installed some CF door panels-imag0050.jpg
Old Sep 15, 2011 | 07:06 PM
a98ws6's Avatar
Look good! How much weight savings? How do they attatch? Price?
Old Sep 15, 2011 | 07:18 PM
saved 9lbs . I used black rivits so you cant see them. he has then on sale for 299.99
Old Sep 15, 2011 | 07:19 PM
fuel's Avatar
i like it.....looks good
Old Sep 15, 2011 | 08:52 PM
jcoosi's Avatar
Did you clear them or did they come already cleared?
Old Sep 15, 2011 | 08:57 PM
thats how they come out of the box
Old Sep 15, 2011 | 10:00 PM
joelster's Avatar
Where did you move the window switches to or are the windows fixed in the up position?
Old Sep 15, 2011 | 10:36 PM
studderin's Avatar
9# per side? any word for a door handle?
Old Sep 16, 2011 | 07:57 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Looks almost exactly like DMH ones that JL has on his car.
They are thin but def do the job!
Old Sep 16, 2011 | 04:45 PM
Timmy P's Avatar
Look just like the DMH ones. BADASS
Old Sep 16, 2011 | 06:02 PM
moved them inside the center consol
Old Sep 16, 2011 | 06:05 PM
NO door handle but something can be easley added the cf is plenty thick
If you compare them to dmh there alittle bit beter quality all around
Old Sep 16, 2011 | 08:45 PM
studderin's Avatar
didnt the DMH save 16#'s
do you mean there 9#s a side lighter or for the pairs?
how are they at the top, do they keep the window form rattleing? Dont the stock door panels have the rubber at the top of them for that? Ive never had my stock door panels off so I dont know much about them.
I think these would give you a bunch of more room. Without the molded "L" door handle in the stocks, couldn't you make you cage doorbar strait and closer to the the door with these?
Old Sep 16, 2011 | 10:39 PM
Mikey 97Z M6's Avatar
The seal at the top of the door panel doesn't hold the window in place. Under the door panel there are a couple of adjustable felt pads that keep tension on the window.
Mike
Old Sep 18, 2011 | 06:13 PM
they are alot thicker and stronger them the dmh. 9lbs total savings
Old Sep 18, 2011 | 08:59 PM
mike135531bubba's Avatar
Looks great. My Wolfe aluminum door panels saved 9 lbs total too I believe.
Old Sep 19, 2011 | 10:20 AM
Fireball's Avatar
so they're heavier then
DMH made them essentially as light as possible.
