Drag Racing Tech
How do you launch.
Old Mar 7, 2004 | 12:15 PM
goober35's Avatar
Default How do you launch.
I just got a PT4000. This think kicks ***. I when to the track and got a best 60 of 1.67. I stalled it up to 3000 and let it rip. I wanted to flash it but it was to cold and i dont think i would of hooked. What is the best way that you have found out with this converter to launch. I know every set up is dif but it might help he a little.
Old Mar 8, 2004 | 08:23 PM
Loudmouth LS1's Avatar
I'd say try holding it at 2000 and then flooring it and letting it flash, works for me! I don't have the same stall, but mine is a 4000 stall, so it should work close to the same!
Old Mar 8, 2004 | 09:24 PM
CamaroCain's Avatar
i would try 2k - 2500 rpms for your launch, my 4400 likes it around 2500.
Have you ever considered stepping up with maybe a 3.73 gear? What is your raceweight? Suspension setup?
Old Mar 9, 2004 | 06:45 AM
scottywheels's Avatar
i set the trans brake bring it to 3800 o the convertor and launch at 8 psi and hold on.
