Drag Racing Tech
ET with Bolt ons and Cam??
Old Sep 23, 2011 | 05:31 AM
Mangum's Avatar
Default ET with Bolt ons and Cam??
I have a couple buddies that are saying that they have had cars with ls6 intake, ported TB, full exhaust and cam shaft and has run 11.0s with this kind of set up. I have a built 347 with heads, cam, fast 90, 1 7/8" headers, converter ETC and having problems getting there on 17s... Just looking for opinions on running 11.0s with stock heads? No nitrous..
Thanks Guys
Old Sep 23, 2011 | 07:35 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Having a conflict here, Built 347 with heads cam fast intake but wanting opinions on running 11.0 with stock heads... I maybe assume you mean stock type castings that been worked over...
Anyways you really need to provide more info about the car. Previous track times, race weight, dyno sheet, and stall speed of the converter. What rear gear.....
Also one thing I will say is you need to get away from the 17's and invest in a good tire and dropping race weight are 2 guarrenteed things that will work if you do nothing else but we need to know how far are you away from the goal.
Old Sep 24, 2011 | 02:32 AM
Mangum's Avatar
Im talking about there car was a stock bottom end stock headed 99 camaro with cam and bolt ons and 4200 stall with 3.42 gear(Not stock style, stock heads with zero work done to them) and of course he was running 15s with skinnys and they claim 11.0s. My car is 2000 SS with 347, dart 225s, cam, fast 90, 4000 stall and 3.73s on 17s and thats about what im getting out of mine. I guess the question is, if he ran 11.0s with cam and bolt ons (Stock Heads and bottom end) is my car slow for built 347 with heads and cam... Both cars full weight with the exception of him running 15s and me 17s
Old Sep 24, 2011 | 07:25 AM
Doug G's Avatar
I don't see 11.0s in your buddies car.
I could be wrong.... but I don't see it.
Old Sep 24, 2011 | 10:18 AM
darrensls1's Avatar
11.0 cam only is NOT the norm. 11.4-11.8 would be closer to normal. Now that's assuming full weight. Do some decent weight reduction and all bets are off.
I ran 11.5-11.7 with my cam only setup and that is with full boltons, fast 90 and very agressive stall/gears. Add decent heads and now you are looking at 11.0 or even high tens on full weight cars.
Old Sep 24, 2011 | 10:20 AM
omar_286961's Avatar
Maybe your buddies have a killer 60ft, otherwise line them up with yours and run against each other and see if it true, if you havent already.
Old Sep 24, 2011 | 10:24 AM
Fbodyjunkie06's Avatar
What kind of rear end and suspension set-up is on his and your car?
lemons12's Avatar
If he was in a gutted car with good da, sure. Otherwise he is bull sitting and running mid 11s at best.
Old Sep 24, 2011 | 11:09 AM
studderin's Avatar
whats weight and tires?
Old Sep 25, 2011 | 11:16 AM
Mangum's Avatar
Both cars full weight with the exception of his having 15s with 275s and mine 17s with 315s. Both cars, control arms, torque arm, stock shocks with mine being lowered, 10 bolts with 3.73s in mine and 4.11s in his. Im not calling the guy a lier im just trying to see if i gotta POS haha. Always ran Fords and my Tube car is a FORD but just getting into the F-Body for street car.
Old Sep 25, 2011 | 12:35 PM
owndjoo's Avatar
it's possible with some awesome air and if he's launchin it real well. def. not the normal thing. now your car should def be able to run that kind of a number. def go with some 15's and a DR or slick.
Old Sep 25, 2011 | 09:32 PM
Zmg00camaross's Avatar
I am sure he doesnt run 11.0s full weight. I have bolt ons and a turd hotcam with hoosier qtp 15x28x11.5 3380 raceweight m6 with 4.56s and got 1.58 60ft ran 11.65 at 117 mph Friday night.
Old Sep 26, 2011 | 09:33 AM
SuperSlow02's Avatar
All depends on weight and set up. I was going 7.3s in the summer and my raceweight is around 3500. Few suspension changes and better air will get me fairly close.
Old Sep 26, 2011 | 09:26 PM
lil_302's Avatar
Get rid the lowering springs!!! The 17's aren't good either but u not to pick low with 17's and slower or little higher with 15's and faster
