Drag Racing Tech
Any suggestions to my setup!
Old Oct 3, 2011 | 10:44 PM
domestic disturbance's Avatar
Default Any suggestions to my setup!
Well guys abt robbed the bank but plan on taking car to the track for the second time and probably last time for the year.... the first time I took the car ofcourse I snapped a axle in the 10 bolt so it pushed me to pickup a qp 9"....
here is my setup and just wanting to see if there is anything that you recomend I change or add over the next 2 weeks before I head to the track...
base hp on motor 400 whp
adder n20 coming in as 2 step disengages 100-150 shot...
will be leaving on 2 step anywere from 3500-5500
Suspension sfc's, adjustable tunnel mount torque arm, lower control arms, relocation brackets, adj panhard bar,
driveline qp 9" 4.56 gears narrowed 6 inches (on order)
Will be running a hoosier 275 60 tire
Car is also a convertible!
Any recomendations on anything to add or change just let me know! I can probably find a few extra bucks to spend if really needed lol!
Old Oct 4, 2011 | 09:33 PM
Ttmft any suggestions
Old Oct 4, 2011 | 11:20 PM
Duffster's Avatar
which transmission?
drive shaft loop???
shocks/springs front & rear?
Old Oct 4, 2011 | 11:53 PM
Originally Posted by duffster
which transmission?
Drive shaft loop???
Shocks/springs front & rear?
m6 (tsp clutch)
umi loop with ta mount
stock front and rear springs and shocks!
Old Oct 5, 2011 | 01:16 AM
Duffster's Avatar
start with something simple adjustable shock in the rear and see your 60's and go from there. Everything else sounded good. Done a weight check on all corners/balance?
Old Oct 5, 2011 | 04:51 AM
bonestock_442's Avatar
Shocks and slicks.
Old Oct 5, 2011 | 08:11 AM
what is going to be my best budget shock for the rear!!!! Wish I could pick some afcos up at the moment, but fundage is def low!
