Drag Racing Tech
Help with shock settings and tire psi
Old Oct 5, 2011 | 07:08 PM
spaulding's Avatar
Default Help with shock settings and tire psi
Heading to the track with a new setup 99 camaro cam only with 400 and tbrake 3800 stall set up for spray makes 380 ish to the tire and roughly 3000 lbs i have bmr xtreme tq arm wolfe single sway bar single adj. Strange shocks up front and double adj. Strange rear shocks and m/t et streets 28 in all tubular front susp and offset adj. Rear lcas im wondering what a good base settings for shocks and tires are along with what way to turn the ***** also not sure witch ***** are what on the rear shocks they have one small one big i had lost my paper work i was thinkin starting at 20psi on the tires any help would be greatly appreciated thanx
