Stock air pump to pull crankcase pressure
Stock pump and and RPM activated switch, or WOT switch to turn the pump on when you're on the wood, would be the best bet. You build the most crank case pressure under full throttle and only go WOT a select amount of times. You get the benefit of a vac pump when you need it most, and hopefully prolong the life for a while.
