Drag Racing Tech
Melling high pressure high volume problems?
Old Nov 14, 2011 | 02:38 PM
00blacka4's Avatar
I write checks with my mouth that my ass can't cash
Default Melling high pressure high volume problems?
Are people haveing problems with the high pressure, high volume oil pumps sucking the pan dry ? i was going to get a ported ls6 or melling high pres/volume but someone said that they are sucking the pans dry with the ported ones or the mellings...true or bullshit?
Old Nov 14, 2011 | 06:36 PM
SSPerformance's Avatar
From what i have read you should run a bigger pan with the high volume pump
Old Nov 14, 2011 | 07:38 PM
00blacka4's Avatar
alright so just go with a ported ls6 ? Or go with a melling stock replacement ?
Old Nov 14, 2011 | 07:51 PM
all i have is a ported ls6 in my 440 with a stock pan
Old Nov 14, 2011 | 09:10 PM
00blacka4's Avatar
do you have any problems with it dropping on launch or at high rpms ect... or "sucking the pan dry" ever ? also have you ever had your motor apart and looked at bearings or checked tolerence ?
Old Nov 15, 2011 | 08:48 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I ran a Melling HV Pump in my 383 LT1 and the guage never had an issues but still blew out the bearings after time and this was over 5 years ago now and if I had to do it again, I would not have opted for it. This was a stock oil pan as well. Its one thing to have good pressure but if your sucking out most of the oil its still going to starve itself over time.
Old Nov 15, 2011 | 09:15 AM
ElkySS's Avatar
i had an hv pump with a stock pan. it did suck it dry. i would have very erratic oil pressure at wot, i switched to a standard m55 and a moroso oil pan and everything is perfect
