Drag Racing Tech
Trans Am Wing
Old Nov 26, 2011 | 07:26 PM
Zero4488's Avatar
Restricted User
Default Trans Am Wing
Does anyone currently make a light weight Trans Am wing?
Old Nov 26, 2011 | 09:57 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Nope. That's why many of us either run a formula/firebird hatch or run the T/A hatch and remove the up-level spoiler.
Old Nov 26, 2011 | 10:24 PM
RamAir95TA's Avatar
Yep...as awful as it looks without the wing it shed a TON of weight.
However the weight is considered "good" weight since it is over the rear tires. Unless you're looking for every last little bit I wouldn't bother with removing it. Finding a Formy/V6 hatch is your best bet.
Old Nov 27, 2011 | 07:35 AM
tektrans's Avatar
Ed Quay makes an aluminum wing with strut kit. The wing bolts to the hatch and will allow you to open and close hatch easily. If you like that look (I do) it will save you nearly 30lbs. Get some speedglass out back and drop close to another 20lbs
Old Nov 27, 2011 | 09:11 AM
Firehawk441's Avatar
YES.
Call Shawn Zubler 1-215-651-7677
He makes a Carbon Fiber version of the OEM T/A wing.
http://www.kosmotorsports.com/
Old Nov 27, 2011 | 10:16 AM
csjta2's Avatar
RJ Race Cars also lists one, never seen one, but you can contact them and ask
http://www.rjracecars.com/Pro-Series...-Prodview.html
Old Nov 27, 2011 | 11:09 AM
y2k_ta's Avatar
'Bird Director
Heck, I have a Formula hatch that I can't even give away.....
