Drag Racing Tech
Race wiring help?
Old Nov 28, 2011 | 09:05 PM
charlie97z28's Avatar
Default Race wiring help?
Jus bought a engine harness for my build question is what about vats? Is that in the PCM or the bcm. What do i need to do to get the csr to crank. I seen on painless and other wiring sites there is a module for vats bypass. Tried the search didn't find anything. Jus trying to figure out all what I need this is the first time I've been this far into removing all the wiring.
Old Nov 29, 2011 | 11:42 AM
5.3LJimmy's Avatar
What year is the harness and PCM? What car are you putting it in?
I believe the VATS bypass modules will only work with 1998 and older PCMs.
If this is a 4th gen with a BCM:
The BCM reads the pellet in the ignition key. If the BCM does not receive the correct signal the car will not crank. You can get around this by grounding the starter relay directly instead of allowing the BCM to do it.
The PCM needs to receive the signal from the BCM to turn on the fuel pump and pulse the injectors. If you bypass the BCM you will need to have the VATS turned of in the PCM. You can purchase tuning software and do this yourself or find a tuner that can do it for you.
Old Nov 29, 2011 | 09:31 PM
its a 98 harness and it goin in a 4th gen body but there is nothing left but a hull im starting from nothing so there will be as little wiring as possible.
Old Nov 29, 2011 | 09:55 PM
5.3LJimmy's Avatar
In that case I would just have the VATS turned off in the PCM.
Old Nov 30, 2011 | 12:23 AM
Will I be able to crank it or will it have to be turned off first
Old Nov 30, 2011 | 09:15 AM
5.3LJimmy's Avatar
It will crank and run for 2-3 seconds then shut off if the VATS has not been disabled.
Old Nov 30, 2011 | 06:54 PM
studderin's Avatar
I started a thread on this with some good info. Im gona fishing it once it start snowing and a park the car for the winter. I've got 18#s out and still have the BCM and some things I'm gona take out still.
