Drag Racing Tech
New Stock Internal Record !
Old Mar 14, 2004 | 06:50 AM
WILWAXU's Avatar
Way to go Tim!!
My car certainly 60ft and ET better with the little 26x10.5 ET Streets.
Joe.. I think it would have went faster with a Yank
Old Mar 14, 2004 | 07:03 AM
Black Sunshine/ 00SS's Avatar
Nice results. I'd throw a 9" ET Drag on there. I guarantee you will get better results. It's more than enough tire for stock NA, and lighter than what you have now. Go to MT website to get the weights on these tires.
What is your trap RPM's?
Old Mar 14, 2004 | 07:05 AM
RUQWIKR's Avatar
Originally Posted by foff667
i dunno if a radial slick would help or hurt...figure thats probably 20-40lbs of extra rotating mass...not exactly a bolt on cars friend...
Hawkn01...Great runs! Congrats on finally breaking the record. I may just have to stick my stock spare motor in it this fall!!!!
foff667...On the radial slicks, good thing is that they do not require tubes, can be run at much higher pressures, weigh similiar to a bias slick (9" same as 10.5" bias)...however, only come in 29.5" and 29.9" OD (Hoosier, Goodyear, Mickey Thompson, and Phoenix, and only Hoosier does both OD's, the others 29.9" only)!!!
I've got one in the barn (Hoosier 29.5") that I am fitting, or at least looking at. It will require major additional surgery on the rear fascia in comparison with what has been done for 28.5" M/T's even considering their growth.
Anyways, good luck to all and take care.
Old Mar 14, 2004 | 07:26 AM
jfm's Avatar
jfm
Congrats on the kick azz times.I think I had the most fun with my car when it was stock internal running 11.6s.
Old Mar 14, 2004 | 08:08 AM
Flamin Raven's Avatar
Awesome times!! it's guys like you that make guys like me have to up the jets
Old Mar 14, 2004 | 08:39 AM
foff667's Avatar
LS1TECH Sponsor
i thought he was talkin about bfgs...not dot legal bias plys...ive got hoosier QTP dot's for the record and on the same rims they weigh tons less than bfg's or nittos
Old Mar 14, 2004 | 09:01 AM
JGKadell's Avatar
Not trying to be an ***... but witht hat DA nad other factors what does it come out to for SAE corrected times?
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
wow those are unreal times, but looking at the DA and I understand! We can get -500 to -1000 DA in January-February here in Gainesville. Combine that with running in the daytime so the track has plenty of heat and you'll get some bitchin times!
Congrats again, WTG
Derek
Old Mar 14, 2004 | 10:15 AM
Hawkn01's Avatar
Thanks everyone ! Yes, I think the Hoosier 26x10 slicks hurt me for sure, but I guess I had to find out the hard way ! Need to get me some 8" rims instead of the 10" and try a smaller tire.
Old Mar 14, 2004 | 12:59 PM
Skelton's Avatar
Congrats! Thats moving out!!!!!!!! Now I have to go even quicker! My car is currently on a 150+ lb weight reduction plan and is getting a trans freshening and about 3-400 more stall. Gonna install the rear sway bar and switch from a 28x10 to a 27x9. This internal stock thing is gonna get interesting. Mine wont be ready untill 4/2 so I might lose out on a negative DA day but gonna give it a try. I have a killer set of ls6 heads and a custom grind laying around but I want to go 11.teens first. Good job man!!
Old Mar 14, 2004 | 02:51 PM
jfm's Avatar
jfm
Hawk,no doubt those 10"rims and Hoosiers are a lot more weight than a set of 8" Welds and 9" ETDrags.
Old Mar 14, 2004 | 02:56 PM
  #32
EVIL's Avatar
10 inch bogarts are lighter than the 3.5 front welds.....they weigh almost nothing.
maybe put the 9 inch et's on the bogarts and see.
Old Mar 14, 2004 | 03:58 PM
  #33
CHRISPY's Avatar
congrats that is awesome
Old Mar 14, 2004 | 07:15 PM
  #34
Hawkn01's Avatar
JFM and Evil, the Hoosiers were on the Bogart P2 series 15x10 Alumalites which are very light. The Hoosier slicks weighed 2lbs less that the ET Street 26x11.50's and I've cut a 1.49 on the ET's with them on a heavier Bogart P1 series rim. Maybe my low range clutches are starting to give up in my tranny, they have been in there since last May.
TJ
Old Mar 14, 2004 | 07:37 PM
  #35
Hawkn01's Avatar
RUQWIKR......... My hats off to you for sure ! I've been chasing your record since last fall. Records are made to be broken, and thats the driving force behind my thinking. Thats the fun of it !! I love drag racing
Old Mar 14, 2004 | 07:43 PM
  #36
WS6FirebirdTA00's Avatar
i take it you have dynoed, just curious on the numbers you put out
Old Mar 14, 2004 | 08:39 PM
  #37
Hawkn01's Avatar
Nope, the car has never seen the dyno. Don't have a clue really ! I don't use Edit either.
Old Mar 14, 2004 | 08:58 PM
  #38
no **** lol question for you, im stayin a bolt on car as far as i know right now should i just stick with gettin an ls6 intake or what about the lsx, is it even worth it? i just wanna get a little more power and better pick up and it seems pricy for the lsx but if its good for a lot of power i might get it... what do u think. what do u use to tune your car?
  #39
promod1955's Avatar
Tim, bring it down and put it on our dyno. Sweet times and can't wait to see it in action on the 3rd.
Old Mar 14, 2004 | 09:11 PM
  #40
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
wow great times! 31XX pounds! damn that is light! i have pulled about as much weight as i want to and the car with me in it will be somewhere in the 33xx range. do you have a cage in the car yet? ls1's are ok in my book
