Drag Racing Tech
hvac delete
Old Dec 16, 2011 | 07:56 PM
95_lt1formula's Avatar
Default hvac delete
I'm wanting to delete my hvac without pulling the dash can I just bust it out from the engine bay and cut it inside n pull the heater core and everything out?
Old Dec 16, 2011 | 08:07 PM
krissoto's Avatar
I don't think that you will be able to remove it without pulling the dash. The unit is pretty large in size. U should pull the dash, that way u can remove all the other unnecessary things that you will no longer need.
Old Dec 16, 2011 | 08:30 PM
outkast6991's Avatar
You can delete the engine bay side without pulling the dash. Makes for easy plug swaps too. You can also mod the box from the bay to retain heat/ defrost. If you need a delete plate let me know. I have one made to bolt into existing holes from the engine bay
Old Dec 16, 2011 | 08:51 PM
TurboStangJON's Avatar
Just pull the dash it takes no time at all.
