Where to mount battery in the back
Thanks
right rear wheel well, say that 3 times! LOL.
heres the relocation i mademyself with some angle iron.
Just wandering what everyone else is doing. Any advantages, weight distributions, traction, ect. from one or the other.
Some people that run 2 batteries put one on each side, 2 in the middle, sometimes one in the middle.. I have seen one in the left side of a car as well... I wouldn't make a big deal about where it is... as long as the car is scaled properly.
Thanks JL
edit: is it this? http://www.wolferacecraft.com/instal.../fbodbulk.aspx
Al 95 Z28
I hear people talk about the PCM getting "reset" from this all the time. I absolutely never saw any ill effect of doing this... so what gives, I'm curious to hear about someone having an issue because of the PCM being "reset"
Never saw any adverse effects from doing this.
Here's an article that explains the use of a double pole switch:
http://www.timskelton.com/lightning/...y_relocate.htm
Al 95 Z28
That is one nhra rule that I'm not really sure how and if they ever inforce... simply becuase alot of factory cars are wired this way. I know the 4th gen f body had a wire that ran right from the alt to the fuse box power lug, and a wire from the battery to the same lug, essentially directly tieing them together.I would like to see someone just have nice double pole single throw switch, so that when the switch is killed it could cut the alt to battery and battery to ign. power.
But, noone really makes one that has 2 sets of contacts that can carry some power. I hate adding extra relay's anywhere, it's just another electronic item that can fail.
Not safe but I pass tech.Al 95 Z28
