Drag Racing Tech
Drag car ride height
Old Jan 2, 2012 | 06:42 PM
CyaPussy's Avatar
Default Drag car ride height
Should it be level higher in the rear etc looking for some opinions.
Old Jan 2, 2012 | 08:16 PM
Tan327's Avatar
With a drag tire and skinnies setup it's going to naturally sit higher in the rear, rear stiff and front soft. You want weight transfer but not too much squat, purpose is to go forward down the track, not launch into space.
Just do some searching, there is 1 thread on here from a while back where PSJ, Madman, and other knowledgeable folks had this discussion, ^ that's basically what I gathered from it.
Old Jan 2, 2012 | 09:31 PM
krissoto's Avatar
I'm at 25 1/2 " and 27 1/2" with a 275/60
Old Jan 3, 2012 | 09:02 AM
CyaPussy's Avatar
I have a inch and half diffrence front to back I know its going to normaly sit higher in the rear just curious if it is better to be closer to level.
Old Jan 3, 2012 | 10:30 AM
sweetbmxrider's Avatar
JL WS6 is good with the ride height IMO, search his posts as he's said it countless times.
Old Jan 3, 2012 | 12:14 PM
ATVracr's Avatar
Pretty close to ours on the same tire.
Old Jan 3, 2012 | 07:48 PM
JL ws-6's Avatar
Race your car!
I played with this a bunch with my own car, and a couple others of varying speeds between 12 to bottom 9 second range...
26 to 27.5 in the back usually seems to work, front usually works at 25 to 26.5 inches.. depending on power level, travel limters and where they are set, what shocks and springs are on the car (decides what you can do with the adjustment to a point). I don't like running alot of rake in the car and I don't like running the entire car any higher then I have to.. I pretty much run it as low in the front and back as I can without having issues with the car bottoming out and without causing issues to load/unload the car on/off the trailer.
Let me say that I am not a radial tire guy and there's most definitely things that need to be changed both with the suspension settings and tuning to get the car to work, so if you are on a radial, the height that I've had good luck with may not work for you.
