Drag Racing Tech
Quick release steering wheels
Old Jan 11, 2012 | 11:28 AM
Slowhawk's Avatar
LS1Tech Sponsor
Default Quick release steering wheels
What are you guy's running? How do you like it?
Looking for a good kit for the stock column. Car has a manual rack, so no tiny wheels.
Old Jan 11, 2012 | 12:58 PM
ATVracr's Avatar
Grant kit from Madman.
Pretty easy to install.
Old Jan 11, 2012 | 01:39 PM
chasgiv3's Avatar
I bought mine from Burkhart Chassis. They have the full kit with the options.
http://www.burkhartchassis.com/id86.html
He should be able to match you up with a different steering wheel if you don't like the standard one.
Old Jan 11, 2012 | 02:23 PM
subhumanzz's Avatar
13" grant pro stock wheel and grant hub from mad man here too. the smaller wheel isnt bad with the manual rack.
Old Jan 11, 2012 | 02:26 PM
blue99fbody's Avatar
how big is the stock wheel? im looking to do this as well and not thrilled about going to a smaller wheel
Old Jan 11, 2012 | 03:39 PM
JL ws-6's Avatar
Race your car!
I put a column in when I did the quick release wheel, but the burkhart, or madman kit would be the way to go with a stock column.
Wheel wise I picked out a black grant wheel that was only like 1/2 an inch smaller then the stock wheel. It's big enough so it's not really a struggle to turn the wheels with 1 hand when the car's not even moving, with the car moving at all it would be easy enough.
The prostock wheel with the yellow marker in the center is a nice wheel as well, no need for the tape on it, etc.
Old Jan 11, 2012 | 03:44 PM
Roger Blackmore's Avatar
I'm using the one from Madman with a 15" Grant,
And a power rack, without the power steering pump. That wheel is the same diameter as factory. It takes an arm to manuver around the pits. I like the quick release. But the setup I got moves the wheel away from you about 3".
Old Jan 11, 2012 | 03:56 PM
JL ws-6's Avatar
Race your car!
Roger you can get a spacer that will pull the wheel back towards you if you want that.
I had the column built 2 inches longer when I took this route for that same reason, later I found some spacers that you can use (ART catalog) that will let you pull the wheel closer.. had I known about those I would have had the column shortened 3 inches from stock and put a 5 inch spacer on that would remove with the wheel... it would make for alot less column in the way when getting in and out of the car fwiw.
Old Jan 11, 2012 | 06:29 PM
MADMAN's Avatar
LS1Tech Sponsor
I have the wheels and quick release in stock. Give us a call.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jan 11, 2012 | 07:01 PM
BlackScreaminMachine's Avatar
Internet Mechanic
I really do like your setup, extremely light too.
Old Jan 11, 2012 | 07:09 PM
spaulding's Avatar
I put a burkhart kit in mine its a nice kit and has a sewn in center stripe on the wheel ive got a manual rack in mine and have street driven it a bunch and its not bad at all to turn the wheel isnt to small if u want ill grab a pic of it
Old Jan 12, 2012 | 08:00 AM
Slowhawk's Avatar
LS1Tech Sponsor
I'll shoot ya a call today Madman.
Old Jan 12, 2012 | 10:19 AM
ShiznityZ28's Avatar
Madman is the way he will send everything you need.
Old Jan 12, 2012 | 10:25 AM
sweetbmxrider's Avatar
I used a stock column with a grant wheel and their pinless quick release hub through summit.
Old Jan 12, 2012 | 12:30 PM
a98ws6's Avatar
Does the kit include the hub and wheel? Is that all that is needed for the stock column?
Old Jan 12, 2012 | 05:07 PM
TurboStangJON's Avatar
I used a Grant quick release with this wheel for a while with the stock column. Seemed to work well but now I have a different column with a Strange quick release.
Old Jan 12, 2012 | 05:16 PM
tt383lt1's Avatar
how much are they from you at madman and will they work on any other colume if i choose to go that route
Old Jan 12, 2012 | 05:22 PM
tt383lt1's Avatar
do you have part numbers?
Old Jan 13, 2012 | 01:26 AM
Fbodyjunkie06's Avatar
I need one of these and haven't done the research on them. How much and how does the wheel come off the column when your getting in and out?
Old Jan 13, 2012 | 05:52 AM
MADMAN's Avatar
LS1Tech Sponsor
http://www.madmanandcoracing.com/sho....aspx?catid=21
__________________
225-343-9029
