Drag Racing Tech
set up/track questisons
Old Feb 6, 2012 | 05:52 AM
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
Default set up/track questisons
Hey guys I've made alot of progress with my build. I'm now trying to figure some things out.
My build is a 2000 camaro ss/slp
9.5:1 comp 402, TU2 cam ( 236/236, .587 .587, 112.5 LSA, stock L92 heads, L92 edelbrock single plane, elbow, 80lb mototron injectors, GT88 1.08 A/R T6 flanged, 2.5" turbo kit, truck manifolds, Moser 9, 3.25 gear, trutrac, 4l80e, transgo hd2
I'm just trying to figure out the best way to run this at the track, I have a few questions about my set up
1) I will be foot braking it does anyone have any proven set ups i plan on running a set of burkhart rear drag brakes. Will that even matter? or should i just run my stockers with an upgraded rotor/pad set up
2) I plan on running jakes 4l80e stall, its the best priced one i could find plus i figured that jake builds a damn good 4l80e from what ive been told so i figured they must know there stalls
3) I was told with foot braking i need a good spring/shock set up, with my budget i will be running stange single adjustable up front with QA1 275lbs springs & Comp engineering 3 way adjustable out back with stock springs.
if anyone can give me any pointers if im on the right track, my goals for the car are 850+ rwhp 700+lbs and a 1.5x 60ft 9.9x 1/4 passes...
Old Feb 6, 2012 | 06:35 AM
MADMAN's Avatar
LS1Tech Sponsor
You didnt tell us what tire you will be using.
If you are foot braking it I would use the Strange dual rear caliper brakes so you can build boost. I also think you are going to need a better adjustable rear shock on the rear.
__________________
www.madmanandcoracing.com
225-343-9029
Old Feb 6, 2012 | 06:42 AM
well the car will be on a 28inch tire, ive been looking at wilwood & strange rear drag bake set ups.
Old Feb 6, 2012 | 10:27 AM
355z28's Avatar
I think your going to need a Dual adjustable rear shock, are you going to run slicks or dragradials? stiff wall?
Old Feb 7, 2012 | 06:23 AM
Ill probably be on a DR mickey et streets, I am probably going to run a single caliper dual piston set up with a loose style converter. i've been reading up on the comp engineering 3 way adjustable rear shocks and dudes are cutting 1.3x
