What else do I need?
First time to the track was with a slp lid , 180 stat, predator tune, hooker muffler and bassini off road y-pipe. I was able to do 13.02 and a 12.99 poor 60 foots
Second time was at a 1/8 mile.
same mods just a air delete and slp ram air box. I ran 8.30s spinning outta hole. Weak trans
This year.. new trans (well a low mileage one with transgo shift kit) FTI 3600, strange s60 with 3:73s and lca relocation, spohn tunnel mounted torque arm, drag radials mounted on stock 16" wheels and Frost tune.
Just ordered the rear end. My car is sitting with a busted ten bolt. Should I do headers while I am waiting? I can get some pacesetters off a guy. Should I port the throttle body any? I don't mind sending my pcm back to frost for a refresh.
I thought about doing underdrive pulley but don't know if it's worth it. I have some subframe connectors that I need to install.
Am I being too optimistic to hope for 12.40s? I've added a good amount of weight so I was thinking of removing rear seats and stuff to compensate. The car has higher miles since the first outting so I am not sure if the motor is getting tired. It still runs good.
- Headers will help improve power, if it does not cost you much and you have nothing but time, why not?
- U/D pulley is generally something you do with a cam install, its considered "free Labor" as you need to remove it doing the job. IF you have the proper tools you can do it. Just need some good leverage and a large breaker bar.
- You never know until you get out there. The car being a auto will run pretty close to the best ET generally the first time out, unless you have zero traction or something odd.
Take as much weight out, clutter and put the front tire hard, and have a set of at least drag radials to help.
