Travel limiters
But I have my limiters bolted to my lower arms with I think is a 1/4-20 grade8 bolt, I dont think its even 3/8th (the chain bolt). So unless you have a single little 3/16 tab on them sideways. Should be fine, check out the limiter hardware, should be smaller then the sawybar tab i bet
In a sense in kinda makes the wheels and assembly yank down on the front end for a second before it's weight is settled and supported.
This way you can set your shocks to get the cars weight to transfer efficiently but reel it in b4 it gets outta control.
You can see in my sig pic how the wheels are supported by the limiters, better the track the less travel u give it.
