Drag Racing Tech
wheel hop
Old May 29, 2012 | 07:56 PM
BuckaroooZ28's Avatar
Default wheel hop
ran drag radials at the track for the first time at the track and had massive wheel hop, i always run slicks and never have issues..any insight??? qa1 coilovers up front tubeular kmember, long adj torque arm with relocation mount, stock rear springs qa1 shocks, lca reclocation brackets, adj panhard...boxed style control arms
Old May 29, 2012 | 08:47 PM
wws699's Avatar
Sounds like you need to tighten up the extension on the rear shocks now that you have a stiff side wall tire. Compression will need to be tighter to. What size tire and what PSI you running em at?
Old May 30, 2012 | 08:21 AM
275/60 15 17lbs 8in wheel
