Drag Racing Tech
Slicks?
Old Mar 31, 2004 | 04:32 AM
Woody99's Avatar
Question Slicks?
I have a 99 z28 conv. and had wanted to throw some drag slicks and racing rims on the rear. i'm just starting to mod. the car, just cai, lid, cat-back so far, but wanted to research what people recommend going with. i'm open to ideas right now, so i was wondering size, manufactuers, full out slick/ DR?, rims, etc. that would work the best on a stock rearend, stock suspension. any opinions would help me out greatly. Thanks.
Old Mar 31, 2004 | 07:35 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
You need to get 10x15 with 7.5 back spacing rims and 26x10x15 slicks. I like the Goodyear or M/T slicks.
Coach
Old Mar 31, 2004 | 08:08 AM
FEAR THE LS1's Avatar
I'm with coach on the specs.
Do you have a M6 or a A4?
The only heads up I would give you is if you run ET Drags or even ET Streets there is a chance you could damage/break your stock rear end. Even a bone stock car could hook hard enough to brake some teeth off the ring gear. You want to go with a set of Drag Radials to start with or until you get a stronger rear end (12 bolt)
FYI: when I started to add power mods to my car I broke the rear end 3 times with drag radials before I upgraded to a Moser 12 bolt.
Good luck dude!
Lee
Old Mar 31, 2004 | 08:26 AM
Fast SS on TNT's Avatar
Don't forget the ARP 12mm X 1.5 knurl extended studs. Do not race on street slicks, or drag slicks without a set of those bad boys. I would even recommend them for drag radials as cheap insurance. Especially if you go with a Weld wheel.
Plan on a new rearend in your future mods list. 10 bolts can take SOME abuse, but rarely last long.
