Drag Racing Tech
when to spray
Old Jun 25, 2012 | 05:02 AM
daniel(sleepysleepy)'s Avatar
Default when to spray
ls1 dyno tuned
over sized fuel pump
slp intake lid
cut exhaust
after market pan. and torquesion bar or somethin like that
automatic stock gears and internals
100 shot Nitrous single nozel wet
hp on motor 330 torque 440
hp on spray 440 torque 480
10.5 street tires parellies
so when do Yall suggest I spray in the.1/4 and 1/8
Posted from LS1Tech.com App for Android
Old Jun 25, 2012 | 05:10 AM
lemons12's Avatar
Immediately...
Old Jun 25, 2012 | 05:20 AM
should I not worry about just spinning ur killing my engine?
Old Jun 25, 2012 | 05:21 AM
its still a daily driver so I can't afford for it to go down
Old Jun 25, 2012 | 05:28 AM
lemons12's Avatar
Gotta pay to play... I missed the street tires... Street tires will never hold a shot out of the hole. Get a real tire under it or don't spray. I wouldn't spray half way down the track, kinda pointless at that stage IMO.
Old Jun 25, 2012 | 05:30 AM
or spray and deal with the spin with the rear suspension upgrade it has no wheel hop and holds straight unlike most street cars
Old Jun 25, 2012 | 08:45 AM
SuperSlow02's Avatar
Most likely wouldnt hook up till around 50mph.... And if your worried about breaking it, don't race it
Old Jun 25, 2012 | 09:22 AM
the way I look at it its gonna break either on the strip or on the street its not if its when I'm just trying to keep it going for as long as I can
 Michael S. Palmer
Old Jun 25, 2012 | 10:01 AM
TransAmcoupe98's Avatar
this...
Old Jun 25, 2012 | 10:39 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Then don't race your car.
Old Jun 25, 2012 | 11:40 AM
either way its getting raced to fun not to I just plan on biting the bullet when somethin happens
Old Jun 25, 2012 | 11:51 AM
BLK95-Z's Avatar
ls1 dyno tuned
slp intake lid
cut exhaust
Thats alot of torque
Old Jun 25, 2012 | 12:10 PM
meant 340 on motor I'm on a.cell phone doin this so I have issues with hitting the wrong button
Old Jun 25, 2012 | 01:04 PM
Internet Mechanic
50-75 hp setting on a WOT switch.
Probably the safest you can do all things considered.
Old Jun 25, 2012 | 01:31 PM
ok thanks man
Old Jun 25, 2012 | 08:46 PM
djsanchez2's Avatar
How about a progressive unit? You could simply ramp up a 100-125 shot. It would be easy on the tires and give you a killer mph in the top end.
Old Jun 25, 2012 | 08:50 PM
I been looking into those right now I'm just using a throttle switch and arming it right after I get traction
Old Jun 25, 2012 | 09:20 PM
djsanchez2's Avatar
They make a really affordable mini controller. Just an option to get you going safely.
Old Jun 25, 2012 | 10:16 PM
I'm gonna eventually get one but my car is really just to say I can cruise but still put good numbers up cause it never fails while I'm sitting in the parking lot enjoying a beer someone calls me out I'm not big in racing just like to prove a point
Old Jun 25, 2012 | 10:43 PM
dannyz's Avatar
OK. From the beginning...
Tell me you are not still on stock plugs?
Did your tune add timing to what it came with stock?
You DON"T have a window switch. So if you spin badly enough on juice, you could hit the rev limiter, which could be a real bummer. In addition to wheel spin, breaking a u-joint
or the 10 bolt rear would also result in pegging the rev limiter. Again, a real bummer.
For now, like was suggested above, jet down to maybe a 50 shot.
It is still quite a bit of improvement and a lot less risky.
Also, and I am just guessing, looking at your tq, I am thinking you are running pretty rich.
