Drag Racing Tech
torque arm mounting
Old Sep 16, 2012 | 07:50 PM
jwc57's Avatar
Default torque arm mounting
UMI torque arm, mine has 2 holes for the from mount on the cross member. Which hole are you guys using with drag radials? Upper or lower?
Old Sep 18, 2012 | 11:33 PM
charlie97z28's Avatar
I used the upper hole idk if it right or not
Old Sep 18, 2012 | 11:46 PM
StraightTimeStirrups's Avatar
Same response I would give!
Old Sep 19, 2012 | 08:53 AM
As detailed as the instructions are from them you would think it would specify but I'm goin to measure my pinion angle was it back from getting tuned
Old Sep 19, 2012 | 07:46 PM
jwc57's Avatar
Thats what I was thinking, I figure the upper hole will hit the tires harder. I just wasn't sure what everyone was having the best results with.
