Drag Racing Tech
5 Point Safety Harness
Old Oct 8, 2012 | 07:58 PM
Mystery Bird's Avatar
Default 5 Point Safety Harness
Which type is easiest to get in and out of?
Old Oct 8, 2012 | 08:09 PM
joelster's Avatar
You want the more expensive ones with the cam-lock style not the latch style. 1 Twist and all of the belts pop off. Does your rollcage have tabs welded onto the back bar? If it doesn't you will want the "wraparound" style.
Old Oct 8, 2012 | 08:11 PM
Yes, the roll bar does have the tabs. I just started installing the bar tonight for TnT this Sat. I will probably be back at 11.5 after adding all the safety equip. That will really be a disappointment.
Old Oct 9, 2012 | 08:57 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Cam-lock style is what you will want.
Coach
Old Oct 9, 2012 | 09:46 AM
deerslayinrednek's Avatar
Mine didn't slow down much when I added my cage in the spring, If you leave the rear seats out it helps cut down the added weight. I went with the latch style because it is about half the price of a camlock harness
With that said......sometimes I wish the car ran 11.60's so I didn't need all the safety equipment
