Drag Racing Tech
my first LS engine build...
Old Oct 25, 2012 | 07:00 PM
LeBron_Hill's Avatar
Default my first LS engine build...
I have been around first gen sbc's for a long time...but I am wanting to build something different for this car. I am wanting to build a LS based engine to do some bracket racing and some heads up index racing. It will be going in a 4th gen fbody. I will be the first to admit that i dont know crap about a ls engine. Here is my delimma...I am wanting to build a 6.0L out of a junkyard and build a cheap as possible engine to just get the ball rolling. I really dont know what all I need to plan on getting. I have heard talks of lq4 and l92 but I really dont know what it all means. I heard the l92 engines have square port heads that will make a much better engine. What kind of vehicle (year, model, and make) do I need to look for and how can I identify the l92 versus the lq4 engines. I know its asking alot but can anyone give me a detailed parts list on what I would need to complete the entire engine? Want to run a carb setup instead of EFI. Like I said this engine needs to be as much of a budget build as possible but I am set of a LS motor. Thanks for your input in advance guys.
Old Oct 27, 2012 | 01:54 AM
03EBZ06's Avatar
Budget = LS1. But, I would get the LS3 (6.2L)/L92 heads for a basic package. You can ID the blocks by the number on driver's rear of block. On passenger front side, the displacement is usually stamped, like 6.2L. Cylinder head numbers are usually stamped on front lateral edge.
Cylinder Heads
XXXX852 Cylinder Heads LS Small Block V8 1999+ 4.8L, aluminum, 61.15cc chambers
10215339 Cylinder Heads LS Small Block V8 1997 346, LS1, aluminum, 68cc chambers
12480005 Cylinder Heads LS Small Block V8 2000 LS1, GTZ, aluminum, 38cc chambers
12556743 Cylinder Heads LS Small Block V8 1999 325, 5.3L, aluminum, truck, van
12558806 Cylinder Heads LS Small Block V8 1997-1998 346, LS1, aluminum, 68cc chambers
XXXXX933 Cylinder Heads LS Small Block V8 1997-1998 346, LS1, aluminum
12559853 Cylinder Heads LS Small Block V8 1999 346, LS1, aluminum, 68cc chambers
12559862 Cylinder Heads LS Small Block V8 1999-2000 aluminum, LS, 4.8 or 5.3L
12559895 Cylinder Heads LS Small Block V8 2000 325 (5.3L) aluminum
12561706 Cylinder Heads LS Small Block V8 2001-2004 325 (5.3L) aluminum
12561873 Cylinder Heads LS Small Block V8 1999-2001 364, 6.0L, LS, 71cc chambers, iron
12562317 Cylinder Heads LS Small Block V8 2001-2004 364, 6.0L, LS, 71cc, aluminum
12564241 Cylinder Heads LS Small Block V8 2000 346, LS1, aluminum, 68cc chambers
12564243 Cylinder Heads LS Small Block V8 2001 346 (5.7L LS6) or 364 (6.0L LS2), aluminum
12572035 Cylinder Heads LS Small Block V8 01-04 364, 6.0L, LS, aluminum, 71cc chambers
Engine Blocks
12550592 Engine Blocks LS Small Block V8 1997-up 346, LS1
12559846 Engine Blocks LS Small Block V8 1998-up 346, LS1
12559090 Engine Blocks LS Small Block V8 1998 346, LS1
12560621 Engine Blocks LS Small Block V8 1998-up 346, LS1
12562174 Engine Blocks LS Small Block V8 1998-up 346, LS1
1240030 Engine Blocks LS Small Block V8 346, LS1 C5R
12559378 Engine Blocks LS Small Block V8 1999-2000 346, LS1
12561168 Engine Blocks LS Small Block V8 2001 346, LS1
12561166 Engine Blocks LS Small Block V8 2001-2004 346, Ls1/LS6
12568952 Engine Blocks LS Small Block V8 2005 364, LS2
12560799 Engine Blocks LS Small Block V8 2006-2007 364, LS2
12584724 Engine Blocks LS Small Block V8 2008-Current 376, LS3
12598723 Engine Blocks LS Small Block V8 2006-Current 427, LS7
12621766 Engine Blocks LS Small Block V8 2009-Current 376, LS9
12569513 Engine Blocks LS Small Block V8 2005 5.3L Aluminum
12551364 Engine Blocks LS Small Block V8 1999-2004 364, 6.0L Iron
12551358 Engine Blocks LS Small Block V8 1999-2003 4.8L/5.3L Iron
Describes Engine characteristics:
http://en.wikipedia.org/wiki/GM_LS_engine
http://en.wikipedia.org/wiki/GM_Vortec_engine
Old Oct 29, 2012 | 06:26 PM
thanks for the help man...now i just gotta find one of these dang things
