Drag Racing Tech
Critique my diet.
Old Nov 26, 2012 | 09:12 PM
I8UR4RD's Avatar
Default Critique my diet.
Just curious. Will I have to go more extreme with my diet to hit really really low 9's or an 8.99?
Id say horsepower around 850-900rwhp TQ around 740-775.
1.3-1.4 60 foot.
I have an iron 390 which will be coupled with a 4l80e
f1-a procharger @ 74k rpm with FMIC
Front sway bar------------14lbs
Bumper supports --------35lbs
Wipers -------------------2lbs
Wiper Motor -------------2lbs
Antenna Motor-----------3lbs
ABS module-------------12lbs
Air Conditioning---------45lbs
Air Pump-----------------6lbs
EGR ---------------------15lb
Foglights/Brackets---- --3lbs
Grille Insert -------------1lb
HVAC --------------------45lbs
Rear seats/brackets------32lbs
spare tire and jack ------37lbs
Street Lites-------------- 50+lbs
Thats 300 lbs gone....not to mention the cats are already gone due to the catback.
1/2 tank of fuel and I weigh 140lbs.
Wallet mods would be K Member, VFN FG hood, AFCO coil overs, apparently the MWC 9 inch weighs less than the 10 bolt, and chromoly suspension parts.
Old Nov 27, 2012 | 11:42 AM
zracer323's Avatar
A MWC 9" weighs about the same as a 10bolt with an aluminum center section and no backbrace. At your HP level you will definitely need the backbrace. Don't forget about the weight you will need to add: rollcage, window net, parachute, etc.
