Need Some Wiring Help
First after I removed all of the airbag harness I was left with just one wire on the "crank" fuse, the heavy off white wire is still there (I think its for the neutral safety switch). The purple wire that was in the airbag harness went to the other side of the fuse. Can I simple put a hot wire in place of the purple wire and fix that? Or what has to be done. I didn't know that the airbag harness tied into the "crank" fuse.
Second question is what is the 2 wire plug under the center console that has a tan wire & a green/white wire? My car used to be an auto and I think its for the shifter release (press the brake to move the shifter), but I can not remember and I can't find where it shows anything on my schematics.
Any help is appreciated guys, I just hope I didn't get too carried away and remove some stuff that has to stay in there
And it look's to me that the "off white wire is acutally yellow? if it's coming off the crank fuse, the purple goes to the "srs" crap, and the yellow goes back to the ignition switch
Thanks bud, I really appreciate it
