Drag Racing Tech
needs some help please
Old Mar 21, 2013 | 06:50 PM
skeeter99's Avatar
Default needs some help please
Im not getting power to my fuel pump, coils, or starter, so it appears i have taken out some wires are something i needed maybe for vats, but i have no idea what the box looks like, or the wires, anyone have a diagram, any help will be greatly appreciated guys thanks
Old Mar 21, 2013 | 09:51 PM
lmt0705's Avatar
start by checking the fuse panels under the hood, one of them controls power for everything you lost i think, did you disconnect the main feed wire from the battery that goes to the post on those fuse blocks for some reason? how did all this happen? give us a little more info on the situation so we can better understand the issue
Old Mar 22, 2013 | 09:26 PM
skeeter99's Avatar
I have the issue narrowed down some, i deleted my headights in the front and some other wires and i must have cut something on accident because i had no starter, pump, or coil power. I replaced the harness with a known good one and now i have no power to my coils, but everything else is working good, i also cut alot of wires under my dash when i was removing some of the mess, what cold i have cut that would kill power to my coils
