alternative ground locations for fbody / battery relocation
The location on the block I tried to bolt the ground to is just above the starter. The place Tick Performance's instructions said to bolt the other end to is the swaybar mount but it crosses the path of the turbo plumbing.
I figure I have two options - use some of the leftover wire I'll trim off from the "power" side to make a longer ground than included in the kit (would probably need 2.5' ground of 1 gauge wire to go around my turbo plumbing) or possibly have both ground wires on the driver's side of the block. I'm not electrical savvy so I don't know if there's a legitimate reason for having a passenger and driver ground on the block but I'm going to have a hard time doing a passenger ground without a 2.5-3 wire.
Thoughts?
