How can I improve my launch?
So little bit of background on the car, it's the v6 in my signature...Has QA1 single adjustable shocks on all 4 corners. Front sway bar is deleted, as is the A/C, it has a lightweight K frame and lower A arms up front...Car weighs in at 3280 with me in it. I'm looking to cut that number down some.
Last season I ran a 13.43 (in the 2 vids below) on 17" vette rims with a 275/50 drag radial. (I normally run a 15" prostar rim with a 26x11.5" MT ET streets tire) the prostar setup is much lighter (about 34lbs total for just the rears)
I know that's a lot of tire and I usually run it with about 28-30psi as it has been hooking like that. So I guess a couple questions here:
a) what is the skinniest tire I can/should go to? a 9.5"?
b) how can I improve my launch? the front shocks were on the softest setting, and the rears were around the middle settings....
c) How does the weight transfer on the below runs look right now? What should I be looking/watching for my car to do? (i.e, how do I know to look for improvement in the launch if that makes sense?)
Here is 2 different angles of the 13.43 pass if that helps any....
up until now it has been look at ways to squeeze power out of the car, I always hear that suspension plays a big role...I want to start squeezing what I can from the suspension now to make a difference
Weight transfer looks decent. The rear body isn't squatting. Looks like the front shocks are throwing the weight back and keeping it there. Might be a little low in the front. Could try raising it up a little and see if it makes a difference. Might be wasting energy getting it to transfer.
Just speculation on the launch. I'm in the same boat as you, just haven't had a chance to put it to practice.
I do think I need to raise the car in the front some as well...question is, how much? I've been told I should lower the rear end as well, do you think that would have any impact?
Factor that, with going back to my prostar rims, with a smaller tire, as well as cutting the rest of the weight that will be coming out of this car, and all the other fun/custom stuff I have to do, plus the fact that this cam makes power to 6500rpm and I was only turning 6000rpm, she'll get there.
My main concern is how to use the suspension I have to maximize the launch. I don't want to leave anything on the table even if it's .001 of a second.
I guess my main purpose here is to learn how to read what the suspension is doing and how I can maybe make changes/adjustments in the smartest way possible that could positively effect the car.
Have you tried launching without footbraking and letting the stall flash? What 60' are you getting now?
Focusing back on the suspension setup/aspect, it's to my understanding that you don't need to be spinning to make tweaks and see gains?...What you don't want to do is to loose power through unnecessary weight transfer, i.e rear end squatting. You don't want the rear end on your car to squat but rather you want the suspension to apply just enough pressure to the tires to keep them from spinning, without having to waste energy on the car kicking back and down.
Now, my car isn't squatting, but I am concerned with the movement upfront...it seems when the car launches the front unloads then falls quite quickly. Would it not be better to have no movement at all? How can you achieve that through setting the suspension up?
No, my tires don't break loose ever at the track, I'm running too much tire for this car with an 11.5" ET streets. I'm going to downsize to a 9.5 this season
I know there is almost a 10lb difference between those two tires vs maybe going with a stiffwalled drag radial? Maybe even going down as small as a 225/50R15 hoosier drag radial if it will hook?
