Drag Racing Tech
Fox Body traction & twist help
Old Apr 6, 2013 | 08:09 AM
74u's Avatar
74u
Default Fox Body traction & twist help
I'm looking for budget traction ideas for my car. The goal is low 10's but I really can't afford to cage it, or buy a bunch of expensive suspension parts this year. The car is virtually stock from the dashboard back. Very straight car and I don't want to twist it up (or wreck it).
I don't really know where to begin...I was thinking about some weld-on (long style) sub-frame frame connectors tied to the torque boxes, boxing the stock lower control arms, and adding some adjustable uppers.
Good plan??? Bad plan??? Suggestions?
If I want to go down the track this year it has to be cheap...like $1000 including two new slicks/DR's...luckily my local tracks don't tech much if at all.
Here is what I have so far...running but still needs a tune;
Chassis -
'89 fox body notch with a tube K-member, tube A-arms, drag struts, Manual rack, manual brakes, battery in trunk, WELD fat & skinnies, fiberglass hood, full interior, 5 lug front & back. Just a wild guess...maybe weighs 2800lbs???
No cage
No Frame connectors/braces of any kind
Stock rear control arms
4cyl springs (I think original) in back
Motor, Trans, Diff-
'00 Z28 LS1 CARB/CAM on nitrous should make ~390NA & 500+ whp on a small shot...powerglide with 4K stall and transbrake.
8.8 w/4.10 gear
26" tall tire
Old Apr 11, 2013 | 08:30 PM
RacerXLs1's Avatar
Parts for ur car are cheap and a dime a dozen. Get some uppers and lowers. Diffently some frame connectors and weld up the torque boxes. It dont take much to get them foxes too hook!
Old Apr 15, 2013 | 10:24 AM
Stroked96Bowtie's Avatar
^^What he said +Antiroll bar...should be no twisting until you hit BIG power.
