Drag Racing Tech
Spohn drag bar setting?
Old Apr 6, 2013 | 10:59 PM
MM98's Avatar
Default Spohn drag bar setting?
Just finished installing this bar & the instructions say not to mess with the end links as they are pre-set to the proper length. My question is, my car is lowered 1" all around & I assume they are set for a factory ride height. Wouldn't it make since to shorten the end links 1" on both sides & then adjust for pre-load on the pass side? Thanks for any info
Old Apr 7, 2013 | 09:08 PM
Boosted Firehawk's Avatar
I read somewhere to leave them at the stock setting. Then at the track to loosen everything up and go from there
