M6 QA1 settings..
I finally got some rubber under my car and plan to hit the track in two weeks. With the pathetic drag radials before and constant launch experimentation, the car did the best with the front shocks set 1 up from full loose, and the rears set 1 down from full stiff. There's 12way QA1s on all four corners, QA1 springs in front, and stockers in the rear.
I surgically installed 28x12.5x15 MT ET Street Bias Plys and based on how it's driving, I'm confident they'll hook decent. I also just removed the front sway bar (which I shouldve done last year).
I'm just looking for input as to the shock settings. Are they going to have to get a touch softer in the rear going from radials to bias plys or should I just start out with where I left off? FWIW, I launch the car between 5200-5800rpm depending on how the track is.
Thanks for any help or opinions.
GL and let us know how it works
If I go full loose or even 1 click, the car seems to unload the rear tires as the nose comes back down. 2 gives some nice pictures but, 60' isn't consistent for me.
If you can afford it, call Santuff in San Antonio, TX. Cured all my ills. QA1s worked as well as anything but the Santuffs. Everybody I talked to before and after buying them loves them. If you can afford them you won't be sorry.
Rear shocks, usually in the middle. My Santuff fronts like compression six clicks from full stiff compression, extention is 1 1/2 turn from full tight. One pass at Ennis I had them one turn from full tight, went 1.27 60', front tires never left the ground. I would never run them that tight on a hot track. Doubt it would hook.
