Bolt on 1/8 mile
The stall only helps a lot of you aren't spinning.
With your mods I would expect a best of 7.8-7.9@86-88mph in the warm/humid air you are most likely running in if you are running a 1.7ish 60ft.
It also has a correction calculator so you can compare the two runs in question. Just take their numbers with a grain of salt.
Thunderstruck is right. You need to post up the whole slip.
You mentioned you spin so maybe a bigger burnout or the track prep just isn't there. I've never had any luck stalling the car up like that when I just take the slack out of the driveline is when I get my best 60ft times.
Looks like your running a 28" tall tire too which with 3.73s isn't helping.
OP: start by doing the easy stuff, change the tires (I'd consider getting a lightweight bias ply tire) and see what that does, if its still bogging than you may need more gear and/or stall.
What I'm getting at is the tires are too big and heavy for his power level, but being a Hoosier DR, I wouldn't blame the tire for the traction issues when spinning.
Just a point of reference...OP's car seems like it needs more stall, less tire, and a better tune. Just my opinion, best of luck.
