Drag Racing Tech
pro and cons of 15x10 welds
Old Apr 30, 2004 | 03:14 PM
smeshey's Avatar
Default pro and cons of 15x10 welds
thinking of switching from 8" to 10" welds looking for any pros or cons to the switch. Also thinking of having 9" installed 2" shorter and changing offset to 5.5 on a 10" rim Thanks Scott
Old Apr 30, 2004 | 05:55 PM
SilverGhost's Avatar
Motorboater
my experience is on a stock width rear only.
pros..can run a wider tire(duh)
tuck in under the fender better, look nicer IMO, not sticking out as much as 8" rim.
cons..LOT more grinding needed to clearance the calipers. if you run a 28 you'll need to clearance the bumpstops, maybe the bumper cover and possible roll the fender lip.
the bumpstops may have to be done even with a 26X11.5..not sure..i run that now, but ran a 28 first so it was done already when I switched.
Old Apr 30, 2004 | 06:02 PM
GIZMO's Avatar
If you order a rear set-up for a 1982-92 F-Body it is a bolt in. You would then need a wheel with 5" back spacing. I run 9" x 30" slicks on 10" rims. The main advantage is that you get a better contact patch on a wider rim with the same tire.
Daren
Old Apr 30, 2004 | 09:49 PM
next's Avatar
I have a Currie 9" that was narrowed 2" per side and just put on a set of Weld 15x10 with 5.5bs and 28x10.5 slick. I don't have any problems with the outer fender lip and run Wilwood brakes so there were no grinding issues.
