Build advice
SLP lid, K&N filter, free ram air mod, throttle body bypass, EGR and AIR delete, descreened and ported MAF housing, Pacesetter longtubes, Paceseter ORY, magnaflow catback, A founders performance Panhard Bar, and a mail order tune by Frost. We have a tack near here that is an 1/8th and my best timeslip is as follows:
Reaction: .9674
60ft: 2.2236
330fft: 6.0416
1/8th ET:9.136
1/8 MPH: 79.91
I know its kinda bad, But i had a bad o2 i didnt know of at the time, and those were on all season tires spinning halfway down the track.
I have a budget of between 1500-2000. I am thinking of some founders performance LCAs, a racing differential cover (people claim they help keep the rear alive, and I dont have the cash for a 12 bolt), A set of Toyo Proxes TQ 255/50/r16 tires, and some bolt on SFC's. What else could i do to help my times within my budget, while still keeping the car streetable? keep in mind also that a lot of the work has to be done at a mechanic, due to my limited amount of tools, so this factors into my budget. Thank you guys ffor any advice and input.
Bolt on subframe connectors, LCA's, toyo proxes TQ drag radials, changed my gears from 2.73 to 3.73.
My old best run was around a 9.1 in the eighth mile...heres my best timeslip from tonight with the new mods:
Reaction: .6461
60 ft:2.0181
330 ft:5.7048
1/8 ET:8.6793
1/8 mph: 83.3
I am kinda disappointed...i figured I would be faster. should i be faster, or am i where i need to be with my mods?
60ft: 1.964
1/8th ET: 8.29
1/8th MPH: 87.07
Your 60ft isn't much worse than mine. What was your DA? I'd also look into getting an actual tune. When's the last time you did a tune up?
You definitely need a good converter. If your funds allow try to do a cam/converter at the same time so they are matched.
I picked up 20hp on the dyno vs a mail order tune. The mail order tune was good, but somewhat conservative. From the mail order tune's perspective, until you can see how the car reacts with timing, fuel, etc it really does have to be conservative so you don't destroy an engine.
DA is density altitude used to baseline performance. It is a calculation of actual altitude, air temperature, barometric pressure, relative humidity, maybe something else. So with two identical cars, one guy runs at a track making a pass at -800', your at a different track that is 2500'. Your car will be slower. And you can calculate how much slower if you know the DA. Your engine is a simple air pump, the more air you can get into it the more power it makes. The lower the DA, the more dense the air, the faster you go.
At my home track the physical altitude is 1200', but the DA is usually 2500' or worse.
Here is a link that goes back a few days http://weather.noaa.gov/weather/NC_cc_us.html
Al
