Drag Racing Tech
Drive shaft and U-joints question
Old Oct 16, 2013 | 08:31 AM
ragtopz28's Avatar
Default Drive shaft and U-joints question
I will be installing a Level VI tranny and SS3600 next weekend (full weight 2002 Z28). I am doing a new mount with the install. Question is what u-joints are recommended and how much power can the stock aluminum drive shaft take? Thanks.
Old Oct 17, 2013 | 08:11 AM
ragtopz28's Avatar
Answer...Spicer GM 3R @ $23 (Stealership wanted $120 each bahahaha) and We'll see...
Old Oct 19, 2013 | 04:35 AM
01ssreda4's Avatar
Precision 234 is a decent joint for $20. The stock DS are .060ish thick so not much.
Old Oct 21, 2013 | 07:40 AM
ragtopz28's Avatar
And you know this because?....Anyone else?
Old Oct 21, 2013 | 09:17 AM
5.3LJimmy's Avatar
I went 9.97 last year with my stock driveshaft and the original factory installed front u-joint. The rear u-joint is the 1350 crossover that came with my 12 bolt. On the other hand my brother snapped his driveshaft on the street power shifting into third.
Old Oct 21, 2013 | 11:56 AM
ragtopz28's Avatar
I'm an auto so, I figured 10 bolt would go before DS issue. And I've heard manuals can destroy them.
