Why did I spin?
http://photosbyjim.smugmug.com/Other...8601&k=sgpszkj
QA1s will run as fast as anything, but I could not stop mine from bobbing up and down when landing with them, or AFCOs. If you don't do big wheel stands that won't be an issue. Loosen up the control arm bushings. No poly stuff needed for drag racing either. Stronger torque arm if your car leaves real hard. The stock one will bend. Mine finally (after many 1.3X 60's) bowed the torque arm enough to run the side of the tunnel. Didn't slow the car, just sounded like crap. Made me nervous, so I replaced it.
I keep reading about guys on here putting that stuff on their cars, and just assumed they were road racing. Guess not.
Ed, another thing I noticed is setting the pinion angle with the adjustable TA makes almost no difference at all. I actually set it to positive 3 by accident the first time I set, then changed to -3 and no difference at all.
When I was running stock rear suspension I removed the anti-roll bar, and just used that air bag. If you use an air bag, just put enough air in it to keep the car from heeling over at launch. With coil springs, you want them just stiff enough to hold the car up. "lowering springs " are wrong also. Shorten a spring and you raise the spring rate. If you want to lower it just use softer springs. Stiffer rear springs, just like stiffer front springs, hurt traction.
Wolf Racecraft make nice weld-in upper spring mounts that fit coil-over springs, which also fit the lower spring seats on a Moser 12 bolt rear, which I still use. That gives you an almost endless selection of spring lengths and spring rates. Helped my car, I ran it that way until I had it back-halved. Worked very well.
I keep seeing kids put them on their cars. smh
I saw somebody on here once post something like "girls squat, race cars don't", well go to an NHRA national event, sit close to the starting line and watch the faster Super Stock, Comp Eliminator door cars, and the Pro Stock cars. The back ends set down, or squat, when they leave.
