Drag Racing Tech
Whats next!?
Old Oct 29, 2013 | 10:49 PM
BrainFreezE's Avatar
Default Whats next!?
Current mods:
Cam (Comp 54-444-11 (XER273) 224/230 .581/.588 114)
Comp Magnum Pushrods
Comp 918 Valve Springs
F.A.S.T. 90 MM Intake Manifold
Nick Williams forged 90 MM Throttle Body
SLP Air Lid w/ K&N Filter
180* Thermostat
Pacesetter Coated Headers
Off-Road Y pipe
Corsa 3" Exhaust
Stock Bottom End/Heads
what else can I do that doesn't involve major tear down of the engine? some more quick mods? for more hp?
Old Oct 29, 2013 | 11:03 PM
trans2000am's Avatar
not much more beside if you are a auto would be convertor then suspension mods
Old Oct 29, 2013 | 11:27 PM
FinalCam's Avatar
SSRA or CHRS1313 ram air are often overlooked. Electric water pump or an underdrive pulley may be a good option.
Parker
Old Oct 29, 2013 | 11:49 PM
I am trying to see where the CHRS1313 installs...
Old Oct 30, 2013 | 12:20 AM
FinalCam's Avatar
I will assume you have a tune, but if you don't that would be a nice place to pick up power
The ram air installs in front of your radiator and scoops air from just below the front bumper. I can take a picture if you would like, or search for other threads if you want.
Parker
Old Oct 30, 2013 | 10:29 AM
looks cool but I really don't want to sacrifice my A/C I know they make compatible ones but I don't know if its really worth $218 for .178 sec increase and 1 MPH in speed lol i may look into electronic water pump.
Old Oct 30, 2013 | 10:58 AM
FinalCam's Avatar
If you won't justify the money for a non AC ram air then don't even look into electric water pumps.
Parker
Old Oct 30, 2013 | 01:06 PM
I mean in reality it is my daily driver, I am not looking to make it fully blown racecar and take the A/C out and gut it out. I just want to add some more horses if possible without tearing the engine apart.
Old Oct 30, 2013 | 01:46 PM
FinalCam's Avatar
You don't have to take the AC out to run a ram air setup.
Parker
Old Oct 30, 2013 | 02:26 PM
Blackpanther99's Avatar
Drag Radials.
Old Oct 30, 2013 | 02:57 PM
Parker
would you happen to know how much hp gain estimated of course would be?
Old Oct 30, 2013 | 03:25 PM
FinalCam's Avatar
In terms of power no, because a ram air effect is not measured on a dyno. Ram air setups that retain the AC have a gain of .1-.2 ET and 1-2 MPH.
That's a very significant gain in my opinion.
Also look into tubular suspension for losing weigh, racing seats, or losing rotational weight. All can be done without sacrificing and daily driving amenities.
Parker
Old Oct 30, 2013 | 03:30 PM
Demonicbird00's Avatar
iirc it works off of pressurization, so on a dyno you might not see a gain, but at the track youll see a tenth and 1-2 mph
And if you dont want to sacrifice weight then add n2o
Old Oct 30, 2013 | 04:57 PM
IIRC? sorry man new to Ls1 community lol
Old Oct 30, 2013 | 04:58 PM
FinalCam's Avatar
If I remember correctly.
It's okay, we were all new at some point.
Parker
