Drag Racing Tech
Need some cam help
Old Feb 5, 2014 | 08:50 AM
Mxjamy537's Avatar
Default Need some cam help
I'm trying to figure out cam specs for my engine build. Have a ls2 block with gm 3.622 crank, Molnar h-beam 6.125 rods, and je fsr dome pistons. Compression is 12.5:1 with ls3 heads. Gmpp carb single plane intake. Will be running a Ron's alcohol injection toilet bowl 1435cfm. Solid morel lifters and crane 1.8 rockers. Haven't found anyone else running this combo. Going in a 2500lb chevelle with a 4500 stall and a glide. Just an 1/8 mile 6.0 heads up car. I have talked to a few companies that said I need anywhere from .700 to .760 lift with a 106-110 lsa depending on who I talk to. My main concerns are will the stock length valve take that much lift, do I need that much lift and is anyone running a je dome? What is you ptv clearence?
Old Feb 6, 2014 | 06:52 PM
Mxjamy537's Avatar
Anyone?
Old Feb 19, 2014 | 08:08 PM
Mxjamy537's Avatar
Well, it's all for sale. Thanks for all the input.
