Battery relocation fuse ?
All the diagrams I have seen where people actually use a fuse, is between the cutoff switch and alternator. What size fuse is acceptable here.
Also why is the starter wire not fused? Its just as long of a run as the alt wire. thanks
The starter is engaged through a solenoid during the actual start-up of the engine not continuous like the alternator so a fuse isn't really needed.
edit: Should've mentioned that like Rene said...I also have my ground fused. Ive done several vehicles like that and never a single problem.
I use 150A but my current system has a different alternator than the factory ls1 unit...in the case of using the factory alternator I would go 175A or 200A since is has a higher amperage than the one I'm using.
and
